IS it on the left or right?
-Have someone stand outside the car while you pass them to confirm this. It can be illusional from the inside of the car.
Does it follow the wheels RPM? Or is it independent of the wheel rotation?
Does it change turning one way or another, going straight, or veering?
IT does not do this on smooth surfaces?
IF it is independent of the wheel rotation, I would be thinking the verticle mount of the lower control arm or stabilizer links.
IF it follows the rotation it can be a wider variety including axle, brakes, wheel bearing....
Need more info on this.
Oct 23, 2009 at 12:07 PM
