2005 Chevy Impala E10 (ethanol and gasoline)
2005 CHEVROLET IMPALA
75,000 MILES • 6 CYL • FWD • AUTOMATIC
GEORGE ASH
The manual states that it is okay to use E10. I have had problems with the injectors carboning up.
Has anyone else had this problem?
Feb 22, 2009 at 3:20 AM
DENNYP
  • 1,824 POSTS
You will have less carbon with E-10. The thing to remember is to only use one or the other.(regular fuel or E-10) If you use a half tank of E-10 with a half tank of regular fuel, you will have problems. Make sure you are using a full tank of one or the other. Also, your fuel economy will be much less when using E-10.
Feb 27, 2009 at 2:09 PM
