2004 Chevy Impala Serpentine Belt
KAYHARRELSON
  • 2004 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 84,000 MILES
Can a worn serpentine belt make your engine run between hot and cold when you come to a stop and start moving? My car just started doing this. I have noticed that I hear the belt sqeaking when accelerating. When I am going down the road at a constant speed the car does not run hot.
Thursday, March 26th, 2009 AT 8:34 AM
RENAUDTN
  • 636 POSTS
The only way your serpentine belt can affect your engine temperature is if it stretches out too much. In this case the belt slips on the pulley resulting in squealing and lack of performance from the water pump (as well as all the other pulleys). It's easy to replace and cost around $15. You should also check your belt tensioner: If the spring is worn, the belt will be loose on the pulleys as well (cost: around $45). There are more possible causes for your problem, so make sure you check your level of coolant, and check for leaks. It is also possible that your cooling system needs to be flushed, or maybe your thermostat is messing with you.
Thursday, March 26th, 2009 AT 1:07 PM
