2004 Chevy Impala Heat
PEDJA
  • 2004 CHEVROLET IMPALA
  • 6 CYL
  • FWD
  • 128,000 MILES
I have 04 Impala and on the driver side blows cold air and on the passenger side it blows hot. I replaced the thermostat beacuse temperature was running cold. Now the temperature is ok but still blows cold air on one side and hot on another.
Thursday, October 28th, 2010 AT 10:28 AM
WRENCHTECH
  • 20,761 POSTS
Do you have dual temp controls?
Thursday, October 28th, 2010 AT 11:16 AM
PEDJA
Yes I do have dual controls
Thursday, October 28th, 2010 AT 11:43 AM
WRENCHTECH
  • 20,761 POSTS
The heat in that vehicle is controlled by a blend door that regulates heated air flow. It is operated by an electric motor/actuator. The problem can be that the actuator is stripped or inoperative or the door itself could be damaged. This is what needs to be determined by examining the actuator and see if it is responding to heat change commands or not.
Thursday, October 28th, 2010 AT 11:44 AM
PEDJA
Any way I can check that on my own or I have to go to mechanic
Thursday, October 28th, 2010 AT 12:25 PM
WRENCHTECH
  • 20,761 POSTS
I don't know what your abilities are. I know you have to be rubber man to get up under that dash.
http://www.2carpros.com/forum/automotive_pictures/561653_Blend_door_actuator_04_Impala_L_S_1.jpg
Thursday, October 28th, 2010 AT 12:31 PM
