Monday, July 21st, 2008 AT 5:05 PM
The drivers door does not lock or unlock using the fob or the button on the door. All other doors work perfectly. I checked the wires going into the solenoid and when the button is pushed power appears. I bought a new solenoid and it does not work either. I checked the old on by connecting it directly to the Battery and it functioned every time. But it does not work when connected to the wiring in the door. I don't know if it is a ground problem or not enough amps or voltage drop or what. Suggestions of places to look?
