2003 Chevy Impala Pumping gas
100,000 MILES • 6 CYL • 2WD • AUTOMATIC
JLH
When ever we pump the gas into the car we have to barely squeese the nossle, It will kick out. We can't even get it to the 1st. latch on the handle. We can only get about 30 cents at a time and when it is bitter cold outside it can be very irritating. We bought the car used wirh no warrenty. Is it a vent or something that can be plugged, and if so can I fix it myself
Jan 22, 2008 at 8:07 PM
BMRFIXIT
  • 19,053 POSTS
[quote:8a8a4d464d="JLH"]Other Category problem
2003 Chevy Impala 6 cyl Two Wheel Drive Automatic 100000 miles
When ever we pump the gas into the car we have to barely squeese the nossle, It will kick out. We can't even get it to the 1st. latch on the handle. We can only get about 30 cents at a time and when it is bitter cold outside it can be very irritating. We bought the car used wirh no warrenty. Is it a vent or something that can be plugged, and if so can I fix it myself[/quote:8a8a4d464d]
check the filler neck
if hoses and tube ok filler neck no good replace it
Jan 23, 2008 at 9:15 AM
DENNYP
  • 1,824 POSTS
You could possibly have a restricted EVAP vent valve that is preventing pressure from escaping the tank when you are filling up.
Jan 23, 2008 at 1:50 PM
