I am not sure what the part is called but it mounts to the top of the motor. Call your local dealer. I dont think they are that expensive. Unless you want to take the a picture of the motor, I can help you fix it with out replacing anything if it is the same style as mine. A picture would help explain to you better what to do
SPONSORED LINKS
Friday, December 11th, 2009 AT 10:59 AM
