2002 Chevy Impala message center
134,000 MILES • 6 CYL • FWD • AUTOMATIC
BIGB46773
my message center says low tire pressure
if anything its to high in tires
how do i reset error code my scan tool doesnt
see error when hooked up
thanks to another posting turn off radio hold disp button for awhile then the radio went to ltdelay push the 1 button and scroll down tile you get to tire pressure push the 3 reset comes up and push 3or 4 might beep and the low tire pressure is off
Aug 24, 2008 at 7:26 AM
RHALL77
  • 3,361 POSTS
you can either set the tire pressure and drive it or take it to the dealer and have it reset
Aug 24, 2008 at 2:46 PM
RENAUDTN
  • 636 POSTS
You can reset it with the radio, like the other post explains; there is also another way although I'm not sure if it works for tire pressure:
Turn your key to 'ON' (engine off), and quickly press on the brake five times (you have to do it within a very short amount of time, but i can't remember how many seconds). If you do it right, it resets your message center.
Off course make sure you've inflated your tires at the right pressure (around 30 psi I believe) before you do all that. One or several of your tires is/are way under pressure.
You scanner doesn't read it because it is probably not a DTC.
Aug 25, 2008 at 5:33 AM
