2001 Chevy Impala Tranny slipping
KHOWARD
  • 2001 CHEVROLET IMPALA
Transmission problem
2001 Chevy Impala Engine Size unknown Wheel Drive Type unknown Automatic 107000 miles
THIS MORNING WHEN I WAS AT A LIGHT MY CAR WOULD NOT GAIN SPEED IN DRIVE WHEN IT WAS TIME TO TAKE OFF. IT STALLED OUT AT A UP HILL LIGHT AND I WAS REVING IT IN DRIVE BUT NO GO, I THEN SHIFTED TO 2 GEAR AND IT TOOK OFF ROUGH BUT WAS ABLE TO START MOVING. I JUST BOUGHT THIS CAR AND IT WON'T PASS SMOG DUE TO THE CAT CONVERTER.
IS THIS A LOST CAUSE?
HOW DO I GET MY TRANNY TO CATCH GEAR?
PLEASE HELP!
Tuesday, January 22nd, 2008 AT 12:02 PM
BMRFIXIT
  • 19,053 POSTS
You cant even check tranny fluid on this car with out a lift
because its done from under the car right by the axle
my suggestion is to have it looked at
or you can try to add tranny fluid which I do not recommend with out checking if fluid low
good luck
Wednesday, January 23rd, 2008 AT 5:24 PM
DENNYP
  • 1,824 POSTS
A restricted cat converter could cause no power or stalling. This is also a common problem on this model. I would have it tested for excessive back pressure over 2 psi.
Wednesday, January 23rd, 2008 AT 9:43 PM
