1995 Chevy Impala cooling fans
190,000 MILES • V8 • 2WD • AUTOMATIC
MUNDO1954
The cooling fans wont come on at all and the car overheats. The fuses and relays are good and i have replaced the temperature sensor and they still don't come on. If I disconnect the wires going to the temp sensor, both cooling fans come on and stay on until I connect the wires back and then they shut off again. The voltage to the temp sensor is 5 volts which is what its suppose to be. There is also no engine lite on.
Feb 11, 2009 at 6:30 AM
DOCFIXIT
  • 18,828 POSTS
Do fans come on with the AC? Check for ground on purple wire you have 5v on yellow. The temp sensor you replaced near thermostat housing?
May 18, 2020 at 10:43 AM
MUNDO1954
[quote:536a727c40="Docfixit"]Do fans come on with the AC? Check for ground on purple wire you have 5v on yellow. The temp sensor you replaced near thermostat housing?[/quote:536a727c40]
The a/c is low on refrigerant so the a/c wont activate the the clutch assembly. I checked the purple to ground and there's about 8 ohms of resistance. I turned on the a/c anyway but the fans didn't come on.
DOCFIXIT
  • 18,828 POSTS
There should be 0 ohms on ppl wire. the 5v go through thermister as temp goes up so does resistence and less voltage gets back to PCM. Which in turn grounds relays for fans. so when you disconnect your signaling PCM engine is max hot 0 volts returned. Ohm across two terms on temp sensor start cold then check as it warms up. If resistence goes up then sensor O.K. Then PCM becomes suspect.
