2001 Chevy Express
BILL65
  • 2001 CHEVROLET EXPRESS
Engine Performance problem
2001 Chevy Express 6 cyl Two Wheel Drive Automatic
If my van idles for a long period of time in hot weather, when I put it in gear and step on the gas it will either hesitate or stall. It is obviously starving for fuel because I have to pump the gas to restart it. I changed the fuel filter but that had no effect.
Tuesday, July 8th, 2008 AT 7:55 AM
SERVICE WRITER
  • 9,123 POSTS
Not necessarily fuel loss. Should check the fuel pressure to see what it is doing when the problem is present. Since it is temp related, it may a coolant temp sensor for example that is reading wrong and telling the pcm to change the fuel/air mix. Unlike a carb, the fuel injection pedal pumping does not have the same effect.
Tuesday, July 8th, 2008 AT 8:06 AM
