2000 Chevy Express pulling
62,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHEVYASTRO
i changed my front brakes an did wheel alligment. the van just pulles to the left. i brake or let go to the steering still pulls. the alligment straight . i put new ball joint. i dont know y is still pulling .di u know y
Apr 10, 2009 at 1:32 PM
  • 31,937 POSTS
Hi there, swap the front tyre left to right, this some times fixes this problem, if the steering is still pulling and not under brakes only, it will be an alignment or steering? suspension issue that has not been corrected with the alignment.
Mark (mhpautos)
Apr 10, 2009 at 1:37 PM
CHEVYASTRO
so i have to chang the front tires an switch them. i did the whole front. change the brakes ,rotors,wheel alligment. this van never in a accident. if i let go the wheel still pulls to the left.now they told me something about the camber what is that ,
Apr 10, 2009 at 1:42 PM
  • 31,937 POSTS
Hi there,
Swap wheel & tyre left to right, the Camber is on of the alignment adjustments, basically its the amount the wheel leans out from center.
Mark (mhpautos)
Apr 10, 2009 at 4:02 PM
