1997 Chevy Express Why does my car Stall when I accelerate.
TWISTERMAN
  • 1997 CHEVROLET EXPRESS
  • V8
  • 190,000 MILES
When the car is cold, about 75% of the time when I press the gas, it stalls, if I let go of the pedal right away, the car recovers. Also when I shift into drive then the car stalls. For the most part the car will idle fine, however once I saw it stall.
If I let the car warm up to normal operating temperature, only 25% of the time when I hit the gas does the car stall. I am always able to shift into drive without stalling.
We just replaced the Mass Airflow Sensor as it was really dirty and malfuntioning.
My parents claimed it backfired once.
What could be wrong? 99 Chevy Express 3500 5.7 L
Monday, August 24th, 2009 AT 8:06 PM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Monday, August 24th, 2009 AT 8:22 PM
RUGABUGADOUGLAS
My van does the same thing ive replaced ons of parts what should the fuel pressure be I was told 65 but mine has 50. I have done the timing chain fuel pump cam sensor cam sensor plugs wires cap rotor distributor tps and mass air flow yet it still spits and spudders on take off
Saturday, December 12th, 2009 AT 5:31 PM
