marble sound with a 95 vette
1995 CHEVROLET CORVETTE
C95
95 vette convert, 72K stand 6 spd, stand V8.
loose marble, percolater sound, 'something in a fan' sound if coming from pass side forward. no other symtoms, just the sound.
constant speed of sound regardless if car is still, or moving, clutch in or out, idle or increasing rpm, (rpm drowns out the noise. No affect if a little load is put on motor, can't hear from outside (Drown out by engine noise)
just had clutch and slave done 2k
Heat shield? cat convert ?
Jun 23, 2007 at 11:55 PM
STRAIGHT AHEAD
  • 41 POSTS
Have the bearing check on the serpentine belt tensioner. Good luck
Jul 23, 2007 at 9:39 PM
