harmonic balencer removal ??
BELFIGLIOVAL
i have a 1994 LT-1 corvette auto trans with 94,000 miles, heres my question i am trying to remove the harmonic balencer { vibration dampener} theres not much room, do i need to move the steering rack first? or try to raise the motor? thanks for any help.
Aug 31, 2007 at 5:35 AM
  • 75,988 POSTS
[quote:1123164ed2="belfiglioval"]i have a 1994 LT-1 corvette auto trans with 94,000 miles, heres my question i am trying to remove the harmonic balencer { vibration dampener} theres not much room, do i need to move the steering rack first? or try to raise the motor? thanks for any help.[/quote:1123164ed2]
You can use a long breaker bar with the correct socket and wedge it determine the direction and crank it over it'll break loose.
Aug 31, 2007 at 11:01 PM
BELFIGLIOVAL
[quote:cc54fe8ab6="rasmataz"][quote:cc54fe8ab6="belfiglioval"]i have a 1994 LT-1 corvette auto trans with 94,000 miles, heres my question i am trying to remove the harmonic balencer { vibration dampener} theres not much room, do i need to move the steering rack first? or try to raise the motor? thanks for any help.[/quote:cc54fe8ab6]
You can use a long breaker bar with the correct socket and wedge it determine the direction and crank it over it'll break loose.[/quote:cc54fe8ab6] [[-- the bolt is already is already out , im talking about removing the balencer itself, as there is no room, raise engine or move steering rack??
harmonic balencer removal ?? that was your Q-you have to raise the engine to get clearance
Sep 1, 2007 at 3:00 AM
