1976 Chevrolet Corvette Battery Drain
JDR1964
I own a 1976 Corvette with about 64000 miles on it. The battery is getting drained through some short in the electrical system, but now even when I charge it up I only get a little rattling or clicking noise. Is this indicative of a bad solenoid and where do I even get to it to replace it?
Aug 17, 2007 at 9:46 AM
  • 75,988 POSTS
[quote:b1fd674f4f="jdr1964"]I own a 1976 Corvette with about 64000 miles on it. The battery is getting drained through some short in the electrical system, but now even when I charge it up I only get a little rattling or clicking noise. Is this indicative of a bad solenoid and where do I even get to it to replace it?[/quote:b1fd674f4f]
Remove the positive cable and stick a test lite between the cable and the battery positve post-if you have a short the test lite will lit-if so start removing fuses one at a time-when the test lite turns Off you have found your problem circuit. In the event you have remove all the fuses and test lite still lit disconnect the alternator-lite turn off -its coming from the alternator. Diodes!!!!
Aug 17, 2007 at 10:36 AM
Suggested Repair
Diagnose the parasitic drain with a test light between the disconnected positive cable and the battery positive post. If it lights, remove fuses one at a time until it goes out to identify the circuit. If it stays lit with all fuses removed, disconnect the alternator; if the light then goes out, suspect failed alternator diodes.
Conversation Summary
The owner of a 1976 Chevrolet Corvette with about 64,000 miles reports a battery drain from an electrical short and only a rattling or clicking noise after charging, and asks whether the solenoid is bad and how to reach it. The expert recommends a test-light parasitic-draw test, isolating the circuit by removing fuses, and checking the alternator diodes if the draw remains.
