1993 Chevy Corvette Change Oil light
1993 CHEVROLET CORVETTE
BLACKKNIGHT47
Electrical problem
1993 Chevy Corvette V8 Two Wheel Drive Automatic 130.00 miles
How do you reset the change oil light?
Sep 11, 2008 at 7:33 PM
BMRFIXIT
  • 19,053 POSTS
To reset oil life monitor, turn ignition on. Ensure DLC terminal No. 12 is not grounded. Press ENG MET button, located on the trip monitor, and release. Within 5 seconds, press and release ENG MET button again. Within another 5 seconds, press and hold the GAUGES button located on the trip monitor.
CHANGE OIL light will begin flashing. Hold GAUGES button depressed until CHANGE OIL light goes out. When light goes out, engine oil life monitor is reset. This should take about 10 seconds. If light does not reset, turn ignition off and repeat procedure.
Sep 11, 2008 at 10:31 PM
