My mechanic found a "sensor" that was reading the engine temp 20 degrees too low. He changed that but it didn't solve the problem so we took it out.
The only other oddity is that the heat doesn't work. I have changed the thermostat but still no heat. One would presume that, if both problems started at the same time, they have a common cause.
SPONSORED LINKS
Sunday, August 23rd, 2009 AT 1:31 PM
