1986 Chevy Corvette fuel injectors
1986 CHEVROLET CORVETTE
28,400 MILES • V8 • 2WD • MANUAL
VETTEATLAST
I wanted to know the correct way to test the fuel injectors on my 86' Vette
Apr 12, 2008 at 2:20 AM
BLACKOP555
  • 10,386 POSTS
the easiest way to test if they are working is to listen for a clicking noise, although it tells if their firing it doesnt tell if they firing enough, the best thing to do would be a cylinder balance test or to take them out and crank the engine and see if they all fire the same.
if they arnt firing then the next step would be to hook up a noid light to the injector harness, and when the engine is cranked it should flash.
Apr 12, 2008 at 2:28 AM
VETTEATLAST
I read that the injectors should have the same ohms or very close to the same ohms when tested with a multimeter. I was wondering what the correct procedure was for test them - by the way, thankyou for responding:)
Apr 12, 2008 at 3:27 AM
