1978 corvette silver anniv.ed.
1978 CHEVROLET CORVETTE
HAPPY HOOKER TOWING123
when i start engine im fine but when i turn ignition off the engine keeps running. back ground information is...car has sat for 10 years without being started. i pulled alt. wires to stop engine with ignition off but power was still running to dash as if ignition was still on. after pulling battery cables off and then reattatching battery cables ignition seemed to be off until i would try to start engine again and i would have to repeat above sequence!!! can you help diagnose problem?
Apr 1, 2006 at 6:35 PM
ROYALRIDER33
EXACTLY what is happening with my 80...First I have heard of this problem and now there is 2 of us. There is a wire running to a connection with a vacuum hose on the other side. It is right on the firewall in front of driver...I disconnected it and the problem is gone. Trouble is, I have no idea what I disconnected...Let me know if you get a real answer...
Mike
Apr 3, 2006 at 5:05 PM
