1996 Chevy Corsica Engine looses power
WFLETCHE
  • 1996 CHEVROLET CORSICA
  • 6 CYL
  • FWD
  • 160,000 MILES
After my car warms up I don't seem to have mid range power. When I give the car a little gas to get up a hill or speed up it doesn't want to go. When I floor it it goes very well. The fuel pressure checks out. A new fuel pump was installed and a new fuel filter. There are no fault lights or codes. I did notce that the temperature gauge is low. I changed the thermostat and temperature sensor but it didn't fix the problem.
Wednesday, July 21st, 2010 AT 12:12 PM
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Wednesday, July 21st, 2010 AT 9:48 PM
