1993 Chevy Corsica turn signal and hazard
SYLVIACAGGIANO
Electrical problem
1993 Chevy Corsica 6 cyl Front Wheel Drive Automatic
i cannot locate the flasher so i can replace it///i need a picture...a clear one
Dec 3, 2008 at 12:36 PM
IMPALASS
  • 3,112 POSTS
Hello - Here is the info your requested There isn't any pic of the hazard warning flasher. My suggestion is purchase it, look in the area it says and you should see the like item. The fuse panel is located behind the left-hand side of the instrument panel, near the shroud. The hazard warning flasher is located behind the left-hand side of the instrument panel in the convenience center. The turn signal flasher is located next to the convenience center.
https://images.2carpros.com/forum/automotive_pictures/248015_Flasher_1.jpg
Dec 31, 2008 at 3:43 PM
