1993 Chevy Corsica Idle Problems
96,000 MILES • 6 CYL • 2WD • AUTOMATIC
SMDUNN
Happy New Year.
My car Idles very high, Ive already replaced Throttle Position Sensor and Idle air control valve Its still Idles fast. I even Adjusted the Screw all the way in, it still idle fast and it also stalls when I stop fast or when slowing down i let off peddle to fast. What is causing this??
Steven Dunn
Volga WV
Dec 30, 2009 at 4:14 AM
BLACKOP555
  • 10,386 POSTS
might be a good idea to check for vaccum leaks or a plugged up pcv valve.
if your getting air in the system that isnt needed the computer will dump more fuel and more air and more fuel means higher idle.
Dec 31, 2009 at 6:22 AM
