1992 Chevy Corsica 6 cyl Two Wheel Drive Automatic
When my car gets hot it cuts off, it will sit and idol but when you put it into gear it stops. And then I have to let it cool off before it will start again.
Sunday, February 8th, 2009 AT 2:17 PM
JDL
MECHANIC
When the problem occurs, have you done any basic testing? When it refuses to start, have a helper crank it while you check for spark at the plugs and injector pulse. If you have neither one, you may be loosing the rpm signal? Are there any codes?
SPONSORED LINKS
Tuesday, February 10th, 2009 AT 10:42 AM
DANNYNORD
MEMBER
WE fixed the car it was the coil pack, thank you for your help.
Wednesday, February 11th, 2009 AT 11:21 AM
JDL
MECHANIC
All three coils went bad at the same time? Well, glad you got it fixed.
