1988 Chevy Corsica no heat
BIGHEN75
  • 1988 CHEVROLET CORSICA
  • 6 CYL
  • FWD
  • 132,000 MILES
My heat is not blowing through the vents inside the car you can hear the motor but there is no heat
Wednesday, December 17th, 2008 AT 10:50 AM
  • 109,896 POSTS
Hi:
The air is directed with vents. If you are not getting any of the air in the car, chances are one of the vents is stuck closed, of there is a vacuum leak. The vents are in the HVAC duct work under the dash. The one to check will be in the ductwork behind the glove box.
Thursday, January 1st, 2009 AT 1:36 AM
