1994 Chevy Cheyenne Rocker Arm Adjustment
1994 CHEVROLET CHEYENNE
207,000 MILES • 4 CYL • 2WD • AUTOMATIC
MHONTS
How do you set or sequence the Rocker Arms adjustment when reassembling engine?
Oct 16, 2010 at 1:17 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
bring each cylinder up to tdc where both vavles are in the closed position. bring it down to zero, where you can just turn the pushrods with your fingers and all of the lash is out. Then turn 1 turn down. that's the adjustment.
Oct 27, 2010 at 6:37 PM
