1987 Chevy Celebrity
JUNIOR0883
  • 1987 CHEVROLET CELEBRITY
Engine Mechanical problem
1987 Chevy Celebrity 4 cyl Front Wheel Drive Automatic
I have a 1987 celebrity my front torque strut has went bad several times what can I do it takes about a week for it to go bad what can I do?
Friday, October 2nd, 2009 AT 1:13 AM
HMAC300
  • 48,601 POSTS
If this is the strut on the suspension, see if the plate that it rides in is ok or that the bolts holding the frame are tight to the body. If you are talking about eh strut that holds the engine from moving back and forth, you probably have a engine mount that is shot. YOu'll have to check all your mounts so the top one doesn't break.
Tuesday, October 13th, 2009 AT 12:56 PM
