1987 Chevy Celebrity
DRAKE ALEXANDER
  • 1987 CHEVROLET CELEBRITY
  • 6 CYL
  • 150,000 MILES
When my 87 chevy celeb peddle gets pushed down to far or starts to climb a hill and you need more gas it cuts out till it go dead. I took of the cataltic convertor cause the honeycombs was busted really bad and stopping it up but it still does it.
Friday, February 26th, 2010 AT 4:42 PM
Hesitation, lack of acceleration, chugging, bogging etc.
Inspect and test all the following listed below:
Oxygen sensor.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Friday, February 26th, 2010 AT 5:42 PM
