1986 Chevy Celebrity Clicking sound when turning ignition
109,000 MILES • 6 CYL • FWD • AUTOMATIC
DERSKIPPER
  • 5 POSTS
I got this car 6 years ago with 67,000 miles on it. As far as I know most of the components are original as only an elderly lady and brother owned it before me.
I've changed the computer, the mass air-flow sensor, water pump, and starter since I've owned it. The battery was changed 4 years ago.
The problem is that it has been hesitating to start recently and even more recently has been making a clicking sound when turning over. Sometimes it has been rough in that it makes the car shake.
Any ideas what might be failing?
Jun 9, 2010 at 2:09 AM
OBXAUTOMEDIC
  • 3,711 POSTS
Well the clicking usually indicates a low or bad Battery or a bad starter. Since you have changed the starter already I would have the battery tested or just replace it since it is 4 years old it is most likely on it last leg. I would also check or have the alternator tested.
Jun 9, 2010 at 1:13 PM
