2000 Chevrolet Cavalier Ringing Noise
REDHOTCHEVY2000
Cavalier, 2000, 96,524 miles, 2.2L OHV engine
my problem is there is a ringing noise coming from my car when idling, or when i release the gas pedal. i thought it was my tensioner going bad, so i replaced that the other day. it worked for a minute or two, but the noise has returned. it is only while in drive, or neutral. i have not noticed it in park.
i would greatly appreciate a diagnosis on this problem.
Jul 10, 2007 at 3:40 PM
E40WATER12
  • 522 POSTS
Is youre car an auto or manual transmission?. Hows the condition of youre drive belt?. I am thinking of the noises you are hearing are from the fuel running through the fuel rail system, My car has been doing it for a bit, No performance troubles with it. Just anoning sound, Its common with 2.2L gm motors. I unless its causing preformance issues, I fix it, If not I wouldnt worry about it.
Good Luck.
Jul 14, 2007 at 8:34 PM
Suggested Repair
If there are no performance problems, treat the ringing as common fuel-rail noise on 2.2L GM engines and do not repair it. Also check drive-belt condition and whether the transmission is automatic or manual.
Conversation Summary
A 2000 Chevrolet Cavalier with a 2.2L OHV engine has a ringing noise at idle and when the accelerator is released, heard in drive or neutral but not noticed in park. Replacing the belt tensioner only stopped it briefly. The expert asked about the transmission type and drive-belt condition, then said fuel flowing through the fuel rail commonly makes this noise on 2.2L GM engines and is not worth fixing unless it affects performance.
