Sluggish Acceleration; rough idle
TRACEY0508
  • CHEVROLET CAVALIER
1998 Chevy Cavalier, 117,000 miles, 2.2, My problem is this: When cold, the car works pretty good. It used to take awhile for engine temperature to reach normal heat (mid-range), but now it only takes about 5 minutes of running for it to reach the half-way point, and it doesn't get any higher. The hotter the car gets, the more sluggish it gets. When at a complete stop, if I push the pedal all the way down, it backfires. Once it reaches about 25-30, it runs okay, but you can still tell that it isn't running smoothly. When at idle, it is a rough idle. A friend's husband has been working on this car for about 6 years and he's checked everything. There is no error lights that are coming on. He's changed the spark plugs, wires, checked the air filters, fuel filters, compression is good, there are no clogs anywhere that he can find. He's suspecting the timing chain and will check it out this weekend, do you have any suggestions what the problem could be? Thanks for your website. It's great! :D
Thursday, June 28th, 2007 AT 3:32 PM
E40WATER12
  • 522 POSTS
Sounds like u need youre coil packs either tested, Or replaced. Also I would replace youre thermostat and coolant temp sensor, See if that corrects anything.
Friday, June 29th, 2007 AT 4:27 AM
TRACEY0508
1998 Chevrolet Cavalier, 117,000 miles; I forgot to indicate in my e-mail yesterday - the coils were replaced the week before. Also, the muffler sounds louder.
Friday, June 29th, 2007 AT 8:39 AM
NICKN
  • 69 POSTS
Get your catalitic converter looked at.
Monday, July 2nd, 2007 AT 6:43 PM
TRACEY0508
Got the car fixed - the timing chain skipped two chains, and it now works like a champ! Thanks!
Tuesday, July 3rd, 2007 AT 8:04 AM
NICKN
  • 69 POSTS
Has that fixed the loudness of your vehicle? And im glad that it makes ur car run and drive better
Tuesday, July 10th, 2007 AT 6:21 PM
TRACEY0508
Yes, the car works and sounds like a charm! No noise whatsoever.
Wednesday, July 11th, 2007 AT 9:05 AM
NICKN
  • 69 POSTS
Good to hear!
Thursday, July 12th, 2007 AT 1:55 PM
ATOALVIS
My car is doing the same thing. Was your main issue the timing chain? Because mine does it off and on and in the same ways yours did as well.
Wednesday, May 11th, 2016 AT 12:58 PM
