Replacing the Ignition Switch in a 90 Chevy Cavalier
1990 CHEVROLET CAVALIER
DRIFTER
I have a "90" Cavalier with over 100,000 miles on it.
It is an automatic on the floor without tilt steering.
I need to replace the ignition switch and was wondering what I need to do to replace it? Like if I need to remove the steering wheel or not , etc..??
Nov 9, 2007 at 2:40 PM
BLACKOP555
  • CERTIFIED EXPERT
  • 10,386 POSTS
easy to do, take and turn the key to the on posistion find the little button or hole on the ignition switch column and push on it while pulling out hte ignition.
Nov 9, 2007 at 8:24 PM
DRIFTER
[quote:8be1913151="blackop555"]easy to do, take and turn the key to the on posistion find the little button or hole on the ignition switch column and push on it while pulling out hte ignition.[/quote:8be1913151]
Thank you, but I need to replace the ignition switch itself, not the key cylinder...
Nov 10, 2007 at 11:52 AM
BLACKOP555
  • CERTIFIED EXPERT
  • 10,386 POSTS
Disconnect the battery
Remove the lock cylinder
Remove the bezel that holds the switch
Unplug
Make sure your new switch matches
instalation is reverse. hope this helps
Nov 10, 2007 at 1:41 PM
DRIFTER
Yes it does . Thank you very much...
Nov 10, 2007 at 5:38 PM
