changing the ignition key switch
CHRIS COBB
i have an 1989 cavalier i need to change the key and tumbler part of the switch does anybody know how to change it
Nov 15, 2007 at 5:20 PM
BLACKOP555
  • 10,386 POSTS
yes sir. first insert the key and turn it to the on position, then get a straigtened paper clip and you should find a little hole, insert the clip in and push while pulling out the ignition tumbler. the ignitioin switch is right under it and is held in place with a bezel, unclip and remove.
Nov 16, 2007 at 12:07 AM
