2003 Chevy Cavalier How to change lights
155,000 MILES • 4 CYL • 2WD • AUTOMATIC
A1BEACHBUG
I was wondering if I would have to remove the whole dash if I want to get to my air conditioning light in order to replace the lightbulb and how easy would it be to also change my gear shift light?
thanks,
Ashley
Jul 11, 2010 at 2:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
the black trim piece should pop up where it goes into the console. use a flat blade tool / screwdriver with tape wrapped on end to protect from scratching and pop up the plastic trim. After that is off, there are 2 clips on the drivers side...lift it up just enough to get your fingers in to pop the little bulb out..it's in the rear of the shift display assembly
as for the a/c selector lights, you will have to remove most of the dash to get to it to replace it
Jul 11, 2010 at 2:53 PM
