2002 Chevy Cavalier REPLACED FUEL PUMP
2002 CHEVROLET CAVALIER
170,400 MILES • 4 CYL • 2WD • AUTOMATIC
SAUNT0821
I HAD A FUEL PUMP REPLACED-3 DAYS AGO- NOW MY CAR WONT START AGAIN..WHAT ELSE COULD BE WRONG?
Dec 20, 2008 at 7:05 AM
  • CERTIFIED EXPERT
What was the reason for the replacement ? Could be a fuse/fuel pump relay, computer controlled of the relay instead of the pump.
When you turn the key to run-do you hear the fuel pump ? If so check the fuel pressure and comeback with the readings this is where we start
Dec 20, 2008 at 7:19 AM
