HAD A THERMASTAT INSTALLED PLUS WATER PUMP, VENTED THRU A SMALL BOLT BY REAR OF ENGINE. HAS NO RADIATOR CAP ON RADIATOR FILLED UP BY USING THE OVERFILL CONTAINER. RIGHT NOW IT RUNS AT 195 DEGREES BUT EVERY SO OFTEN I RED LIGHT COMES ON (BOX W/WAVY WATER LINE INSIDE) AND THEN IT BECOME A LITTLE HARD TO START BUT IT COME TO LIFE WHEN WE CRANK IT UP FOR A FEW MINUTES. WE HAVE HEAT THRU THE HEATER INSIDE THE CAR.I'M THINKING IT MIGHT STILL BE AN AIR BUBBLE INSIDE IF SO HOW DOES IT GET REMOVED, ALL YOUR HELP WOULD BE GREATLU APPRICATED, THANKS.
Dec 8, 2007 at 4:27 AM
