You can get a heli coil kit for the spark plug but is it an easy fix? Yes and no. YOu need to be careful what you are doing with the drilling and installation of a helicoil. You'll need to use red loctite to hold the heli coil, then when it's installed and cured for a little while, a couple of hours should be ok, then install the spark plugs again and start it up. Make sure to put antisieze on the plugs so they won't sieze in the spark plug bores. And find another mechanic if two plugs have come out already.
SPONSORED LINKS
Saturday, March 27th, 2010 AT 6:53 PM
