2000 Chevy Cavalier problem with headlights flashing
2000 CHEVROLET CAVALIER
76,000 MILES • 4 CYL • FWD • AUTOMATIC
REV_JCH
Im having a problem with my 2000 chevy cavalier. The other day the healdights started flashing. It does this with the alarm off, or on. There is a clicking noise in the dashboard, it seems to be towards the left side, left of the steering wheel, and to the right of the fusebox (that is behind the fuse box, towards the inside of the dash. it makes this clicking noise, then the headlights (coulld be the driving daytime lights?) come on, then turn off. It pauses a few seconds (maybe 5-6 seconds?) then comes back on. Its been doing this now for two days. I tried un hooking the battery, re-connecting, but it did it again. Is there any idead what could be causing this?
Thanks,
Sincerely
John
Jan 26, 2009 at 9:22 PM
RHALL77
  • CERTIFIED EXPERT
  • 3,361 POSTS
you may have a wire shorting out causing the relay to turn on and off. or you have a bad relay. swap the relay with a different one and see if it takes care of your problem
Jan 27, 2009 at 6:11 PM
