2000 Chevy Cavalier Loud Hum
2000 CHEVROLET CAVALIER
88,000 MILES • 4 CYL • FWD • AUTOMATIC
KIMTER1009
2000 Cavalier, 88,000 miles. Get a very loud humming noise from the front end while driving. This occurs whether in gear or just coasting out of gear. I believe I've eliminated the tranny with this. I do not notice clicking noises (my daughters car), does this eliminate the CV joints? What else would it be?
Nov 28, 2008 at 12:26 AM
MMPRINCE4000
  • 8,548 POSTS
Raise car, put on stands. Grasp tire and pull/push both horizontally and vertically looking for any movement. If movement then could be a bearing/hub.
Check the CV boots for rips, tears and leaking grease.
Finally, move front tires to rear (do not cross, just left front to left rear), if noise moves with tire, then the tire is the problem.
Nov 29, 2008 at 1:34 AM
