You want to know what sensor helps to turn the electric radiator fan on. There are a couple. Of course the radiator fan relay must be working in order for this to happen anyway, so you must verify that the fan works by hardwiring the fan to the battery, if it comes on, obviously its good. But also the engine coolant temp sensor, will tell the computer that its too hot, then in turn the computer will send a ground to the fan to make it come on
SPONSORED LINKS
Friday, April 9th, 2010 AT 10:12 AM
