1999 Chevy Cavalier idle going up at neutral
DOMINIC88
  • 1999 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • MANUAL
  • 210,000 MILES
Hi guys I just finish my mechanic class and I never heard of a problem like this.
i have a 1999 cavalier z24 2, 4l manuel with a peep flow. When I start the car there is no problem its when im on the road for about ten minute every time I shift a soon as I pass neutral the rpm goes up to about 4000 rpm and then if I put it in gear and release the clutch the rpm drops to normal. If I give it a quick shot of gas at neutral then the rpm goes back to normal
could it be my iac or my peep flow who does that. I have no mat under my pedals.
Sunday, August 8th, 2010 AT 7:52 AM
MMPRINCE4000
  • 8,548 POSTS
IAC could be part of problem, could also be a vacuum leak or the throttle body plate sticking.
Sunday, August 8th, 2010 AT 8:37 AM
DOMINIC88
So if I clean my throttle body it should be fine? If it was a vacuum problem wouldnt it be permanent?
Last night I gave a couple of quick stroke on the gas and the rpm drop down to normal it sounded like 1 backfire and it was fine after. Took the car this morning no problem everytime I shifted the rpm drop to normal while in neutral.
So just put some intake air cleaner in the throttle body while I rev it thats it?
Thnak you very much mmprince4000 for the quick answer
Sunday, August 8th, 2010 AT 9:10 AM
MMPRINCE4000
  • 8,548 POSTS
I would start by spraying lubricant (silicone) on TB linkage, if problem persists, remove TB and clean inside and out.
Monday, August 9th, 2010 AT 7:44 AM
