1998 Chevy Cavalier wont shift out of first
SHOOKDE
  • 1998 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 96,000 MILES
I got a 1998 chevy cavalier. It has a 2.2 engine with a three speed automatic. It wont shift out of first, but the reverse gear works. There are no check engine lights on. Can you help me please.
Saturday, December 20th, 2008 AT 6:42 PM
MMPRINCE4000
  • 8,548 POSTS
There is a hydraulic problem with the trans. Hydraulic pressure is controlled by a TV cable or the PCM.
If equipped with a TV cable, then it may be broke, otherwise the PCM or solenoid or relay is bad.
It is best to have it checked by a trans. Shop. Do not drive for any extended period of time with this condition, as the trans can overheat.
Sunday, December 21st, 2008 AT 9:39 AM
SHOOKDE
What side of the transmission does this cable attach to?
Does it attach to a nipple looking piece where the throttle cable attaches to?
Monday, December 22nd, 2008 AT 4:23 AM
MMPRINCE4000
  • 8,548 POSTS
TV cable attaches to throttle body then to oval shaped connector on trans.
Monday, December 22nd, 2008 AT 9:26 AM
