1998 Chevy Cavalier check engine light
EPIZIO
  • 1998 CHEVROLET CAVALIER
Electrical problem
1998 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
I am trying to fix my daughters car. She certinly can, t afford repairs herself. There are two codes causing light. Knock sensor and crank shaft position sensor. I could change these myself, only problem is I don't know where to locate them. Can you help me please.
Thank you in advance
Tuesday, December 9th, 2008 AT 2:45 PM
DOCFIXIT
  • 18,828 POSTS
Hi
CKP crank sensor
2.2L right side near oil filter
2.4L left front above oil filter
Koock right side block
Tuesday, December 9th, 2008 AT 3:30 PM
EPIZIO
I' m not a mechanic, that's why I asked these questions. Near oil filter or above oil filter I understand. Right side of block. What's that mean? Right side of block in the front or back when your looking at it from the front or the side because the engine is side mounted and not front to back. I'm sure you can be a little more specific.
Thanks
Wednesday, December 10th, 2008 AT 2:48 PM
DOCFIXIT
  • 18,828 POSTS
Right side is towards firewall should be near transaxle
Wednesday, December 10th, 2008 AT 2:52 PM
