1997 Chevy Cavalier Manual Trans Pops into 2nd when trying
130,000 MILES • 4 CYL • FWD • MANUAL
LEORIHN
I installed a remanufactured manual transmission from ManTrans.com about 10k ago (out of warranty, and they don't have a clue how to help). I have an intermittent problem where if I try to go into reverse the transmission jumps into 2nd gear. When it does this, the trans is locked in 2nd and I can't get any other gear. I can only fix it by taking the gear selector/relay plate on the trans (the one that the shifter cables go to) off and manually resetting the three plates inside the trans. It seems like the top plate is 1-2, middle plate is 3-4, and the lower plate is 5-R? When this 'jump' happens, the top selector plate (inside the trans) jumps over and the shifter pawl can't get back into position to get it out of 2nd. It must manually be reset. Frequently, doing several 1-2 shifts of the shifter while the clutch is in assists with getting the shifter into reverse and not having the 2nd gear engage. ANY recommendations are welcome at this point. Many of the Techs I talk to are lost on this one. Thanks!
Jan 28, 2008 at 10:43 PM
JRT
  • 27 POSTS
DOES IT MATTER WHICH GEAR YOU ARE SHIFTING OUT OF WHEN GOING INTO REVERSE? OR IS IT MORE OFTEN COMING OUT OF SOME GEARS THAN OTHERS?
Jan 28, 2008 at 11:07 PM
LEORIHN
No, not really. It is usually happens when I first get in and I need to back out of a parking spot. If I try and go right into reverse there can be a little bit of resistance. If I were to let out the clutch at that point, it pops into 2nd. If I leave the clutch in and do a 1-2 shift it usually slides right into reverse. If it doesn't I do the 1-2 again until it goes right in.
Jan 29, 2008 at 12:00 AM
JRT
  • 27 POSTS
YOU MAY WANT TO GET THIS.
Purchase the Mitchell1 Online Repair Manual.
SEE AUTO REPAIR MANUALS ON SITE MENU.
ONLY $9.99!
Jan 30, 2008 at 11:16 AM
