1996 Chevy Cavalier Transmission is leaking on top of exhua
SDAVIS12S
  • 1996 CHEVROLET CAVALIER
  • 4 CYL
  • FWD
  • 178,000 MILES
I need to get a diagram of the transmission to find out which hose leading from the transmission is leaking next to the exhaust manafold. It has now been leaking worse since the other day. Please help me.
Tuesday, July 27th, 2010 AT 7:33 PM
It should be obvious which tranny cooler line is leaking it needs close order inspection
Tuesday, July 27th, 2010 AT 7:47 PM
SDAVIS12S
I need to print off a transmission diagram so I can locate which hose and reapir it. Can you steer me in the right direction so I can print off a diagram of the transmission.
Tuesday, July 27th, 2010 AT 9:16 PM
