1995 Chevy Cavalier Air Conditioning not working
PELIGRO911
  • 1995 CHEVROLET CAVALIER
  • 4 CYL
  • 220,000 MILES
My air conditioning does not work, the switch light turns on but the compressor does not kick on. I changed the compressor and it worked for like two days and all of the sudden it just stoped working. I checked all of the fuses and they are all good. What can you diagnose from that?
Wednesday, August 26th, 2009 AT 8:51 AM
  • 31,937 POSTS
Hi there,
I would be doing a leak test on the system, get it vaced down and make sure its holding a vacuum, start here.
Mark (mhpautos)
Wednesday, August 26th, 2009 AT 9:13 AM
PELIGRO911
I already did a leak test, and it dosent have a leak. What ealse can I do?
Wednesday, August 26th, 2009 AT 9:23 AM
  • 31,937 POSTS
You will have to get the system pressures check, also check if there is power at the compressor, and try jumping power to the compressor to see if it is working.
Mark
Wednesday, August 26th, 2009 AT 9:45 AM
PELIGRO911
Ok so by jump starting you mean rum wires and connect it directly to the battery right? And it has pressure my uncle did a full scan on the compressor.
Wednesday, August 26th, 2009 AT 9:52 AM
  • 31,937 POSTS
First see if you have power at the compressor, and if not, you will have to trouble shoot back, but you will need to make sure that the system has sufficient refrigerant and the clutch is working first.
Mark (mhpautos)
Wednesday, August 26th, 2009 AT 5:27 PM
