Electrical problem
1994 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
I have a 1994 Cavalier 2.2L 4 cylinder. About a month ago, I replaced all the plugs on the engine, along with the plug wires and Ignition coil. The reason was that it was missing. I noticed when I pulled the plug on the cylinder that is 3rd from the left, it was fouled with oil. I also put in a fouler cover to stop this. But since then, I've had a worse problem with it now burning out the tip on that same cylinder of it burning the tip on the plug completely out. Any Ideas on a fix to this?
Oct 21, 2009 at 6:30 AM
