1994 Chevy Cavalier Codes 32 and 66
231,000 MILES • 4 CYL • 2WD • MANUAL
TRUCKER889293
I have a code 32 in this car, I have replaced the EGR and The EGR solenoid and cleared the codes. I drive the car a short distance and the check engine light comes on and I have code 32 again. Whats up?
Dec 11, 2008 at 3:06 AM
BUDDYCRAIGG
  • 2,262 POSTS
It doesn't happen very often, but I've seen a bad engine temp sensor for the computer cause a code 32.
Dec 11, 2008 at 3:18 AM
JDL
  • 16,098 POSTS
The code doesn't tell you what part to replace, just that the system set a code.
Did you test for vacuum at the control solenoid and valve?
With the key on, is there voltage at one of the wires for the control solenoid. Those wires are B+ and cycling ground. The ground may not cycle unless your driving down the road? I wouldn't replace anything without testing.
Dec 11, 2008 at 4:35 AM
