1988 Chevy Cavalier changing belt
RUFUS2
  • 1988 CHEVROLET CAVALIER
  • 6 CYL
  • FWD
  • 73,000 MILES
Trying to replace the belt, can't find tension release. Not much of a mechanic help
Friday, January 15th, 2010 AT 6:22 PM
BLUELIGHTNIN6
  • 16,542 POSTS
1. Loosen the accessory-to-mounting bracket bolt(s) and adjusting bolt.
2. Rotate the accessory to relieve belt tension.
3. Slip the drive belt from the accessory pulley and remove it from the engine.
If the engine uses more than one belt, it may be necessary to remove belts that are in front of the belt being removed
Friday, January 15th, 2010 AT 10:22 PM
Related General Content
