1991 Chevy Caprice my temp gauge goes higher then normal
KEVINLOKEN
MEMBER
1991 CHEVROLET CAPRICE
V8
2WD
AUTOMATIC
281,568 MILES
Hey there I just replaced a lower rad hose cause mine blew so anyways when I dorve the car after the temp gauge once the car was warmed up it would go to the half way point but then keep climbing all the way up to the tick just before the red and just so u know before I blew the hose the temp gauge would never go past half its just weird it will go up high like I said and stay there for a few minutes then finally come back down to where it should be but ill press the gas pedal to pass someone on highway and it will go up again my anit freeze is up and whatnot im pretty sure all air bubbles in coolant r gone car blows hot air I thought it could be thermostat but I was told if its putting out heat then its fine? Thanks alot
SPONSORED LINKS
Thursday, November 26th, 2009 AT 12:02 PM
MECHANIC
Best check the Stat could be sticking
Thursday, November 26th, 2009 AT 4:13 PM
KEVINLOKEN
MEMBER
I opened my air filter and it was pretty caked with oil or gas im clueless with this stuff lol its a throttle body injection I have what could cause this?
SPONSORED LINKS
Thursday, November 26th, 2009 AT 6:57 PM
MECHANIC
Your problem has nothing to with an airfilter being all caked out with oil/debris-lucky its starting up
Could be the coolant temperature sensor fooling you or the gauge is out of calibration.
